Eiswolf pump noise problem
mrkita
I've had my Eiswolf (in a loop with an eisbaer LT solo and Nexxxos V2) for about 2 months now, and I've noticed in the last week that the pump has developed a terrible rattling noise, especially after the loop heats up. My temps look fine, and the pump is running full speed (I've tweak the voltage with no change in the noise other than the whole thing gets a bit quieter). I spent 3 hours the other day refilling the loop and getting the air bubbles out, and although at first it was better, it came back quickly.
Video demonstrating the noise, that it goes off when I disconnect the pump header, and that the noise comes back on when I reconnect the pump header can be found here.
Would a pump replacement please be possible? I have everything here to refill it (would be my 4th time...) myself.
Back
