EduCampi
Hello,
So I'm building something with brass tubes, and I was about to buy the following fittings:
Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 for brass tubes - knurled - chrome
That was cause they seemed a bit different than the normal ones for hard tubes.
Now, it seems there's a new model for hard tubes that it says is also for Brass.
Alphacool Eiszapfen PRO 13mm HardTube fitting G1/4 - chrome
My question is, which one should I get for brass tubes?
Thanks!
Thanks!
