ENTERPRISE SOLUTIONS: New Eisblock ES Acetal for Quadro RTX PNY A6000 GPU
Thomas_S
Administrator
The acetal water cooler with aluminium backplate for PNY RTX A6000 graphics cards is specially designed for use in narrow server cases. In order to save space in width and height, the connections have been moved to the rear, which also enables easier tubing runs within the server rack. Despite the compact design, this acetal water cooler has the same performance features as the coolers in the Eisblock Aurora acrylic series.​
Alphacool Eisblock ES Acetal GPX-N Quadro RTX A6000 with Backplate
Technical data cooler
L x W x H232 x 97,35 x 19 mm
Material cooler topacetal, brass
Threads2 x G1/4“
Thickness cooling fins0,6 mm
Technical data backplate
L x W x H177,07 x 97,35 x 6 mm
Materialaluminium
- PNY RTX A6000, 48GB GDDR6, 4x DP (VCNRTXA6000-PB / VCNRTXA6000-BSP)
