Expand an Eisbär loop with an Eisblock
Anékdoto
Anékdoto
Hi, it's me again. I have an important question.
Since the GPU block is nickel-plated, which coolant should I use? I have already bought distilled water. I haven't assembled the complete loop yet, so I still have time to do things the right way if need be.
Could you please advise me?
Metropolis34
Yes i can. Please add some anti corrosion fluid to distilled water like the one on the link below to be on the safe side;
Anékdoto
Hi, thank you for answering. The fluid is already on the way.
What I have noticed now, is that I don't have any O-Rings. I guess I have to order some. Could you please tell me how many I need for my GPU block? Just 2 (for the tubes) or 4 (2 for the tubes, 2 for the plugs)?
Anékdoto
My bad, I've found the O-Rings, 1 for each tube. I also have 2 caps, each with 1 O-Ring, and each wich 4 extra ones (nice!).
The strange thing is that the GPU block kept leaking a tiny bit, so I've added 1 extra O-Ring to each tube and now it's running without issues (tested 2 hours). Is that normal?
Anékdoto
Anyway, the loop is finally completed and everything is running fine. At last I don't have to hear the GPU fan ramping up, because the temperatures are low.
