Ask for a reference design gpu More options...so. is anyone wants to exchange a 3070 fe against my gigabyte ?
Yes you can.can i change my cpu block/pump for an other one like one u sell in solo ?
I overlooked that it is a gigabyte card. Gigabyte uses a custom PCB for their GPU. So its not that likely that we will make an AIO for it. Sorry my mistake.
I hope that my last answer helped you anyway.
We have a list but it is very far from complete.how can i know witch card is pcb référence card ?
Yes, the pump of the Eisbaer would struggle with 2 radiators + 2 coolersI currently have a Aurora 280 CPU and guess that I would need a extra pump as well if I buy the 3070 block and a radiator?
Ok I was worried the stronger pump would ruin the Eisbaer. I’ll leave it and save the money.You can stay with the Eisbaer, no problem. There is no need to switch on a normal cpu water block.
