Gigabyte GeForce RTX 2080 Ti TURBO 11G (rev. 2.0)
zorko1000
It is GV-N208TTURBO-11GC
rev 2.0, if I'm not mistaken (the power connectors are on not on the top as in the screenshots, but at the rear side of the card).
Thanks!
zorko1000
To be more specific: This image shows the PCB of Rev 2.0. The power connectors of Rev 1.0 are in the position where the arrow points.
I found YouTube "instructions" on how to move those connectors to make a cooler for Rev 1 fit. But maybe there is a better solution? Maybe the cooler itself can be modified to fit this PCB layout?
zorko1000
Thank you for your answer!
Is this cooler available in an AIO package? I'm new to watercooling and was hoping I could use Alphacool's simple plug-and-play system.
