Numlocken
Hi!
I'm working on my new build inside the Phanteks Evolve Shift X using a 3700x, 5700XT and the Asrock ITX-3 (for some reason uses the Intel mounting bracket for AM4).
I would like to hook it up to a single AIO cooler.
I have the Eisbaer 280MM, however I seen to have an issue where the CPU Eisbaer is too tall for me to be able to close the case. I read that there's also the Eisbaer LT. Would I be able to buy the extension kit for a 90 degree angle and the Eisbaer LT and just replace the CPU block?
My second question would be I to switch the Eisbaer LT solo for https://www.alphacool.com/shop/cpu-...lock-xpx-cpu-intel/amd-polished-clear-version while still using the extension kit?
My final question is, I'm thinking of water-cooling my 5700XT, if I have the previous set up, would I be able to use this https://www.alphacool.com/shop/gpu-...exi-gpx-a-amd-radeon-rx-5700/5700xt-reference GPU block inside the same loop as my CPU and my 280mm radiator and still get decent temperatures? Would it make a difference if I add another 2 fans to the radiator?
Thanks in advance!
Thanks in advance!
