GPU Temp Advice Alphacool Eisblock Aurora Acryl GPX-N
JulesMK
Hi,
I have an Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 Gaming X, gaming for about an hour the GPU is around 54 degrees C (water temp is around 34). I wondered what the temp other people manage to achieve?
The CPU (intel i9 9900k) sits about 64 degrees ish.
The GPU OC is Graphics 2255 MHz - Memory 7201 MHz 104% (250w) Power OC using Afterburner and is stable (makes no difference if I don't OC)
The cooling system is:
Corsair 280MM x 30MM rad in the top 2 x Corsair ML140 Fans exhaust
Corsair 360MM x 30mm rad in the front 6 fans push (3 x Corsair ML120) pull (3 x Corsair LL120) intake.
120mm Corsair LL120 fan exhaust on the rear of the case, plugged in to the CPU fan header
Corsair XD5 pump
Corsair XC7 CPU water block
Alphacool GPU Eisblock (Ice Block) Aurora Acryl GPX-N RTX
