GPU waterblock compatibility for MSI RTX 4080 Super X TRIO
killpilot
hi all and staff,
i just buy a new GC to replace my old AMD 6900XT, i search a compatible GC waterblock for my new card... after check in the compatibility tool in some reseller, I'm not sure what I've found.
someone could you confirm which model of waterblock is compatible with my MSI RTX 4080 SUPER X TRIO... i see this : https://shop.alphacool.com/shop/gpu...ol-core-geforce-rtx-4080-suprim-mit-backplate but .... is for SUPRIM X .... is compatible ?
thanks for your help.
regards
Vanzin
Hi,
following water blocks could be compatible with your GPU.
