GPU Watercooling for XFX AMD RX 590
Thernel
Hi,
I recently purchased an XFX RX 590 graphics card and am annoyed by the noise it makes. I have therefore considered installing a water cooling, but I can only select ASUS and Powercolor in the GPU configurator. Does this mean that AlphaCool watercooling is not compatible with this graphisc cards?
Metropolis34
Hi There, yes this is true most of the blocks from the 57X 8 and 9 series are EOL and we do not produce them anymore. Do you have the possibilty to shoot a photo of the PCB without the original cooling on it? We could check the other blocks and try to find one which fits your graphics card.
Thernel
As this would void the warranty and I would have to reassemble and waste a pack of thermal grease without knowing whether or not this helps me getting a water cooling system I really want to avoid doing this. If this is the only way I’d probably rather go AiO even with all their drawbacks
Metropolis34
I can understand you totally it is not 100% sure that we would find a block for this card. And yes you will loose your warranty :(
