GPX-A PPRO+Alphacool Eisbaer LT240 CPU
Timon
I want to ask if that would be a good or bad idea and if any1 has done it. I can only use the LT because the normal Pumo from the AIO is to large
You mean to put both together to one loop? If that is your question.... yes, works fine.
If you have at least a 240mm radiator for the CPU, then you will have better temperatures on average. This means, however, that the temperature on the CPU may be a few degrees higher, but a little lower on the GPU. It all depends on the load distribution. Overall, however, it is always better to connect both together, as the heat can then be distributed more evenly over both radiators.
