beff_jezos_amazon_king
i have
- 17379 16mm to g1/4 compression fitting
- 18444 16mm hardtube acrylic
and there's _no way_ the acrylic tube is going past the 2nd o-ring in the fitting.
with a caliper i measured the outside of the hard tube at 15.95mm - great, perfect. the interior of the compression fitting measures 16.1mm - great. i measure the inside of the 2nd oring while it's inside the fitting (no tension)- uh oh 14.9mm. o-ring itself measures 2.46mm thick, 19.87mm diameter on the outside- so 19.87 - 2x 2.46mm is about the 15mm.
i looked up the issue and saw a handful of people with similar complaints and suggestions and i've tried all of these:
- chamfering tool
- oiling the tube and fitting
- "reseating" the o-ring(?) in place with a 15.5mm ish object (back of penlight)
i went off script and tried these:
- took out 2nd o-ring from bottom fitting, stretched it which of course does nothing what was i thinking
- cut a small segment of hardtube so it would fit in bench vice jaws, tried pressing them into one another
nothing gets the tube past this second oring. i remember from my first build the hard tube should seat further. if it just sits against the 2nd oring, it's less than a millimeter into the assembled fitting and will come out very easily.
am i missing something?
- chamfering tool
