i7even
Greetings everyone
I'm trying to get an Alphacool Eiswolf for my HP RTX 2080 OEM.
The same do not have a good cooler at all, I get +80c every time, I need to set the fan up to 80% to get 60c which the fan is very loud.
So I ask little help to find good Alphacool Eiswolf cooler or if their any will fit on my Graphic card.
I try to find the PCB number but I think there is none since is an OEM card.
The only thing I did find was PN and other weird reference (I think).
Other information i found about the card
I hope someone help me
Thanks
HP RTX 2080 OEM Specs
NVIDIA TU104, 1710 MHz, 2944 Cores, 184 TMUs, 64 ROPs, 8192 MB GDDR6, 1750 MHz, 256 bit
www.techpowerup.com
Thanks
