Hi,
I need some help with my Build, to cool an R7 Ryzen 2700x.
Everything works fine, and have normal temps on my build 71° on full load at 25° ambient.
Until my last maintenance, where I found my rad need a refill due to evaporation (3 years of use)
So, I decided to add some new parts to my Eissbaer 360 LT, to improve flow, an easy refill, if possible reduce fan speed, and be prepared to upgrade to an R9 5950x
For this, I bought an Eisstation + DC LT Pump 2600rpm + UT60 Xflow 120mm Rad to add to my loop...however, I have several issues during my build, so I decided to remove the original 360 rad and keep the Xflow rad for now...which I think has a better flow for my case. (See attached)
The thing is that I have worse temps, in fact, I have thermal throttling, now! my CPU is at 60°-75° for basic stuff, to +85° when I do CG rendering
I have checked and refilled my loop several times and I think everything works fine.
So, I think it's the mounting bracket or something like that...but I tried several times to remount it, and I reapplied thermal paste (also changed the brand, just in case)...without any good result. Also, I checked the instructions, but I can't find the correct way to fix this. I know the nuts and bolts are correct positionings, so what could be causing this?
what am I missing here?
Please let me know.
I really appreciate any help to fix this.
Best Regards.
Nicolas.
Please let me know.
Best Regards.
Nicolas.
