I have had this pump now running around 4 days. This pump has very annoying high pitch tone (similar as coil whining or dry bearing), this is not the normal motor running noise. Shame, since I liked the size of this pump/reservoir combo...
Have you had similar/any issue with this pump? After quick googling, it does not seem to be so quiet pump and quietness is the thing I am looking for my water cooling system.
I need to find another pump that I can actually use in a desktop computer that is around 50cm away from me. Any suggestions?
