How can I replace the fittings that come with Eisbaer AIO?
Kyuss
Hi,
I have installed an eisbaer pro aurora 360 and an esiwolf in my system. I want to cut some tubing because I have too much and my case is small-medium sized (Asus AP201). I want to use custom length tubes but I don't know how to get rid of the fittings and use some regular ones (or maybe even reuse the standard fittings).
I have unscrew de plastic cover of the standard fittings but there is another thread and I don't want to force anything. Are these radiators not able to use regular metal threaded fittings?
Hi,
sure, you can replace the fittings. Our radiators are using a normal standard G1/4" thread. You can simply unscrew the fittings and replace them.
Hi,
Ok, but how can I unscrew it? in the photo I have unscrewed the plastic cover but then a thread shows. what tool I must use? How can I unscrew a threaded part?
Hi,
you can simply use a open-end wrench, or a pipe wrench. I have marked in your photo the area for these wrenches.
Back
