Cyber MageKnight
i noticed my lt240 came with radiator screws but they don't quite fit snuggly there is a good amount of space left between where they stop going in and the radiator/fan
I'm using 120x120x15mm slim fans not the standard stock fans I'm using the formed t1 case that's why im having to use slim fans its why i got the lt240 and not the normal 240 aio from alphacool anyone know where i can get radiator screws for the lt240 that work with slim fans that are 120x120x15 mm in dimensions? if alphacool can custom make such screws ill order them custom but where do i order such screws and how
