Daniel Farrand
I have the Alphacool Eisbaer and Eiswolf. Is it possible to connect the coolant lines between the two of them in series to make one system?
If I were to trim the lines due to how long they are, what kit would you recommend?Then a circuit is easily possible via the existing quick-release fasteners!
Are you trying to connect them in sync?I can't answer the question, but Eisbär+DDC won't settle down together and the flow rate decreases everytime. I tried everything. Would Eisbär and Eiswolf work well, because the DC-LT2 pumps are similar?
Hello. The pump power of the DC-LT2 pumps is sufficient to operate the system and the combination of DDC and DC-LT2 is not a problem. A picture of your system would be great to find out exactly why your performance is decreasing.I can't answer the question, but Eisbär+DDC won't settle down together and the flow rate decreases everytime. I tried everything. Would Eisbär and Eiswolf work well, because the DC-LT2 pumps are similar?
Right now it has only a ddc in it (Under the 200ml resorvoir), the flow starts higher than with Eisbär installed and does not drop. But the cpu temperatures takes long to cool back down when putting a game in background or idling. 3800X NFSU2 game about 65°C. I experimented with putting ddc and water tanks in the 5.25" bays, but that's silly. When I installed a regular cpu cooler, the ddc immediately was able to stabilize the flow. All configurations with gpu and cpu in the same loop. One DC-LT2 is not enough to run the whole loop with gpu, cpu, upright tube, 240 resorvoir, 280 resorvoir, 200ml tank, (DDC), (small 5.25" bay resorvoir).Hello. The pump power of the DC-LT2 pumps is sufficient to operate the system and the combination of DDC and DC-LT2 is not a problem. A picture of your system would be great to find out exactly why your performance is decreasing.
