• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
Is partial radiator obstruction ok?
Lucid
If i mount a 360mm radiator on the bottom intake of my case with the fans below it in push, and then have the vertical mount for the GPU sitting on top of 1/3 of it, is that okay? How much will it affect performance?
Redulon
Member
It is behind the Radiator and the air is already thru it. So it will not have so much effect. As long as there is about 2-3 cm gap, it will have nearly no effect, it will provide some extra airflow on your graphics card :)
