Laing DDC310 does not work anymore.
Fraggle009
Dear all,
the performance of my pump (Laing DDC310 - Complete Edition Eisdecke - silber/Plexi) has decreased very much. The coolant is now only pumped through the system in droplet form, although the pump is driven at full power.
Can you help me with my problem?
Thanks in advance
Frank
Fraggle009
No problem. I just attached the video. Unfortunately I was forced to cut the video to reduce the size.
I hope it is sufficient for you.
Frank
  • 20200929_133752_Trim4.zip
Fraggle009
Hello,
I added another Video. Hope you can see it better now.
I bought the pump from Mindfactory.de but it is a Alphacool DDC310 pump
Best regards and thanks in advanced.
  • video1.zip
