LED Diffusion gel/tape for Alphacool Core block?
wheaton4prez
I have an Alphacool Core waterblock that is working great in my loop.
It's mounted the traditional GPU way (not turned with a riser). So, the issue I have is that the LED lights in the water block tend to shine "raw" through the edge of the block.
I'd like to add a strip of material around the edges of the block to diffuse that light. Ideally, it would be some of that white rubber/silicone that is used on a lot of LED products. But, I haven't found it so far in a sheet or a tape.
Does anyone know of any product that would be good for this and look clean/professional?
Back
