I seem to have lost the user manual from my Alphacool Eisblock GPX-N Plexi Light Nvidia Geforce RTX 2080/2080Ti M02 (2070 & 2080 Super). Any chance some one link me a PDF version of it?
Sorry to bring this old post,i have this one with a 2070 Super from Gigabyte compatible with this block
but i had takeit of, for some reason the gpu doesn't make propercontact and the temperatures are very high (80º+) while playing
Any clues?
Thanks
Hi, why did you take the block off? Did you replace pads? Replaced thermal paste etc.? In the first instance, I can well imagine that the pads or thermal paste no longer have sufficient contact with the components.
I mounted with new pads and following the instructions, the ones for the 2080 in the manual, but i think the block didn't make proper contact with the gpu chip. The thermal paste didn't spread enough, in the block there was just a tiny bit.
Why did I take the block off? Now it's not the time to risk a gpu
