I think I must have tightened the screws too much, because one, maybe two corners of the mounting hardware on the back-side of the motherboard are cracked and broken away from the main plastic mounting bracket...
Does anyone know how I can order a replacement, or if other mounting hardware (from e.g. other CLC AIOs) might be compatible? I intend to try using a more durable mounting plate/bracket (can someone tell me the proper term for this? I'm referring to the plastic plate that goes on the back of the motherboard/behind CPU socket, so that the cold-plate/pump can screw into it.) from other AIOs/CLCs that I've accumulated over the years. I'll be sure to post my findings afterwards, in case anyone else runs into this problem.
