Crazyengineer
Hello.
I ordered Mining Cube 300 from Mindfactory and later found alphacool website. I noticed from the Mining Cube pictures that it has some hoses ready assembled.
Can you recommend me following items to my Mining Cube
- PWM DDC pumps 2pcs (I understood the Mining Cube 300 comes with reservoirs which require 2pcs DDC pumps)
- Controller for PWM DDC pumps
- Controller for PWM Fans
- Hose to CPU block 1pcs (soft tubes)
- Hose from CPU -> GPU Block
- Hose from GPU -> Mining Cube
- AMD AM4 CPU Block 1pcs
- Drain Valve 1pcs
I was thinking to use soft tubes with hose clamp springs for simplicity.
Later on I will add 6pcs water cooled GPU:s to the system. Any considerations I need to take to account when I add these to the loop?
(My mining 5700 cards are **itty ASUS DUAL 5700 EVO, same PCBA as ASUS TUF 5700)
- Drain Valve 1pcs
