Whispermode
Hello!
I have 2x Eiswolf 2 AIOs for 2x TUF 3080 Ti.
I understand that it's OK to have them in the same loop using both pumps and rads. Some questions please:
1. In what order is it best to link them? pump > rad > pump > rad ...or... pump > pump > rad > rad?
2. Is it possible to run both pumps off the water pump header (36 watt header on ROG Hero Z690) with a Y-splitter cable? (I'm not very watt/volt/amp savvy)
...and if the above is possible, would it be possible to add a 3rd Eisbaer pump into the loop for the CPU?
Many thanks in advance.
