need some advice on the alphacool eisbaer aurora 420
flyaway
hi, im currently doing my new build, and i've been contemplating the eisbaer 420 series for a while now but i cant find too many reviews on it. I mean obviously, its you guy's product so you wont bad mouth it but on the other hand i think you guys know it better than other people. its gonna be for an am5 build, waiting on the 9950x3d to come out. So basically, some of the questions i have:
a store near me has the aurora 420 but not the pro. in terms of quality is there a big difference? also, it says its upgradeable so for example, (i plan doing a custom loop later on) if the pump fails or i wanna do something else with it, can i ditch the block/pump and reuse the radiator and change the tubes? I'm mainly putting a 420 in my case for aesthetic reasons for now but i obviously want a good product too in terms of reliability but the warranty on it is only 2 years for some reason... and its already been what 3 of 4 years it came out so its fairly old as of today...
besides that can you tell me more about it?
The normal Aurora is indistinguishable from the Pro version in terms of quality. The Pro version was originally intended for Threadripper and has a larger radiator base. However, many customers now use them on normal mainstream sockets such as AM4/5 and LGA 1700/1851.
The AIO can be extended using the quick-release fastener. Of course, you can also disassemble it completely, as all components come from the DIY water cooling sector. However, if you disassemble it, the warranty will be void. Because it is actually an AIO and not a DIY cooling system. If you want to tinker, I wouldn't buy an Eisbaer but go straight for DIY. That would be much easier.
We give a 3-year warranty on the Eisbaer. What exactly do you want to know here?
Back
