Lukaz
Hello,
I have a problem with the Alphacool Eisbaer 360 CPU is out of order. The product after connecting to the motherboard through a connector dedicated to the water pump does not start the pump / device. The result is a lack of water flow and consequently no cooling of the processor. The device also does not work after connecting directly to the power supply via the adapter and also after connecting to other fan connectors both in the motherboard and the external fan controller by NZXT.
It's brand new product from Aquatuning shop and even if box was sealed, after unboxing I have noticed that G1/4 fits are scratched (used? montage?).
Could you advise me what to do with that particular problem that occured with NEW product ?
Thank you for replies.
// Lukaz
// Lukaz
