• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
New! Alphacool Rise Aurora 140mm - high performance fan with brilliant aRGB lighting!
Thomas_S
Administrator
Alphacool presents the Rise Aurora fan in the 140mm version. Just like the 120mm version, the speed range of this powerful fan is controllable via PWM and it has a brilliant digital RGB LED illumination.
The Rise Aurora fan enables an extremely high air throughput of 154.1 m³/h and has a very high static pressure of 2.20mm/H2O. This makes the fan a great option for radiators or as a particularly powerful case fan. Thanks to the 4-pin PWM connection used, the fan can be controlled over a speed range of 0 to 2000 rpm. At 0% PWM control, the fan stops completely. The smooth start-up increases the service life of the fan and also reduces the risk of injury. In the low speed range, the fan is almost noiseless and thus perfectly suited for silent systems.
The unique and noble illumination is generated by 24 digitally addressable 5V RGB LEDs. Thanks to recessed diffusers, the light is evenly distributed and the individual LEDs are hidden. The individually controllable 5V aRGB LEDs paired with the special design of the fan create brilliant lighting effects.​
Alphacool Rise Aurora 140mm Fan
Technical data fan
L x W x H140 x 140 x 25 mm
Speed0 - 2000 rpm (+/-10%)
Connection4-Pin PWM
Voltage12V DC
Power consumption6,6W (max)
Static pressure2,20 H2O
Max. air flow154,1 m³/h
Noisemax. 38,4 dB(A)
Speedometer signalYes
Technical data aRGB
LED type5V aRGB
Connection3-Pin JST
Max. current consumption LEDs3,5W
LED quantityFrame: 16 / Hub: 8
