More performance for Geforce RTX 4090! With the Eisblock Aurora, Alphacool presents new, innovative coolers for active water cooling of Gigabyte, Asus, Palit as well as Gainward graphics cards.
In order to dissipate the enormous waste heat of this graphics card generation as effectively as possible, numerous optimizations have been made to the water cooler compared to the previous models. The fin structure has been adapted and allows a very effective water flow while simultaneously increasing the cooling surface. The modified jet plate with improved inflow engine ensures optimum distribution of the water on the cooling fins.
The fully chrome-plated copper base is resistant to acids, scratches and damage. Additionally, the chrome plating provides homogeneity and shine that cannot be achieved by nickel plating. The illumination from the digitally addressable RGB LEDs is even better distributed throughout the cooler thanks to the chrome plating. The Aurora design of the Geforce RTX 40XX Eisblock Generation is visually quiete and sleek because only one O-ring runs around the entire cooler. Also, the design around the cooling fins and jetplate makes for a cleaner look.
The Eisblock Aurora water coolers for Geforce RTX 4090 Gigabyte Gaming OC & Aorus Master, Pallit GameRock (OC), Gainward Phantom and Asus TUF & ROG Strix GPU's are available for pre-order now from the Alphacool Online Shop.
Features Eisblock Aurora
- chrome-plated copper cooler
- optimized fin structure with enlarged cooling surface
- the modified jetplate ensures an optimal flow through the cooling fins
- brilliant aRGB LED illumination
Compatibility Eisblock Aurora Geforce RTX 4090 Strix/TUF
- ASUS TUF Gaming GeForce RTX 4090 OC (90YV0IE0-M0NA00)
- ASUS TUF Gaming GeForce RTX 4090 (90YV0IE1-M0NA00)
- ASUS ROG Strix GeForce RTX 4090 OC (90YV0ID0-M0NA00)
- ASUS ROG Strix GeForce RTX 4090 (90YV0ID1-M0NA00)
Compatibility Eisblock Aurora Acryl GPX-N RTX 4090 GameRock/Phantom
- Palit GeForce RTX 4090 GameRock (NED4090019SB-1020G)
- Palit GeForce RTX 4090 GameRock OC (NED4090S19SB-1020G)
- Gainward GeForce RTX 4090 Phantom
Compatibility Eisblock Aurora Acryl GPX-N RTX 4090 Aorus Master/Gaming
- GIGABYTE GeForce RTX 4090 Gaming OC (GV-N4090GAMING OC-24GD)
- GIGABYTE AORUS GeForce RTX 4090 Master (GV-N4090AORUS M-24GD)
