Christopher.W
Member
With Core Storm and Core Hurrican, Alphacool provides further complete water cooling sets that contain all components for setting up a performance-oriented CPU cooling.
The sets differ in that Core Storm comes with SoftTubes, while Core Hurrican comes with HardTubes.
Due to the included mounting hardware, the bundled CPU coolers are compatible with all common mainstream sockets from AMD and Intel. Even AMD's newest AM5 socket can be water-cooled with the Core Storm or Core Hurrican sets with ease.
The sets are not only aimed at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. By using the Alphacool quick-connect coupling included with the Core Set, the loop can be easily expanded with additional components such as radiators, GPU coolers or sensors without having to drain or rebuild the water loop.
The choice of materials for all metals (radiator, cooler base, connectors) is still uncompromisingly based on copper and brass, which not only enables performance-oriented CPU cooling, but also guarantees durability.
The fans and CPU cooler also feature brilliant aRGB lighting. The digitally addressable LEDs provide many options for outstanding illumination of the entire water loop. All cables (aRGB, PWM) and controllers needed to use & control the pump, fan and aRGB lighting are included.
The accessory package also includes important tools such as filling aid, ATX 24-pin jumper and SubZero thermal paste. Thus, you can start building the custom loop "out-of-the-box" immediately.
Features Alphacool Core Storm XT45 Water Cooling Kit
- Eisblock XPX Aurora CPU Cooler
- Core 100 Aurora Reservoir & VPP Apex Pump
- NexXxoS XT45 240mm/360mm/420mm Full Copper Radiator V.2
- Rise Aurora 120mm/140mm Fans
- 13/10mm AlphaTube HF & G1/4" Eiszapfen fittings
Features Alphacool Core Hurrican XT45 Water Cooling Kit
- Eisblock XPX Aurora Edge CPU Cooler
- Eisblock Aurora D5 Acetal/Glass 250mm Reservoir & VPP Apex Pump
- HardTube Eisrohr 16/13mm PETG & G1/4" Eiszapfen Pro 16mm Fittings
Compatibility
Intel: 115X / 1200 / 1700 / 2011 / 2011-3 / 2066
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5
Compatibility
