The Alphacool Eisblock Aurora acrylic GPX water cooler with backplate is now also available for MSI Radeon RX 6700 XT Gaming X graphics cards.
More performance! Voltage converters and V-RAM is now cooled much better and more effectively with liquid cooling. This is due to the components being brought closer to the cooler through the use of thinner, yet more powerful Thermal pads. The reduction of the thickness of the nickel-plated copper block to 5.5mm and the constant optimisation of the water flow within the heat sink promise a significant increase in performance. In addition to performance, design also plays an important role. The addressable digital RGB LEDs are embedded directly in the cooling block and give the cooler its very own visual touch.
Alphacool Eisblock Acryl GPX-A RX 6700XT Gaming X with Backplate
Technical data cooler | |
L x W x H | 246,38 x 141,75 x 26,6 mm |
Material cooler | Nickle-plated copper |
Threads | 4 x G1/4“ |
Thickness cooling fins | 0,6 mm |
Illumination | Digital RGB LEDs |
Technical data backplate | |
L x W x H | 246,38 x 117,25 x 6 mm |
Material | aluminium |
Color | black |
- MSI Radeon RX 6700 XT Gaming X 12G, 12GB GDDR6, HDMI, 3x DP (V398-007R)
