New Enterprise Carbon/Copper GPU Cooler for RTX 3080/3090 & RX 6800/6800XT/6900XT/6950XT
Thomas_S
The new ES GPX Copper/Carbon water cooler with backplate is specifically designed for Alphacool's Enterprise Solutions. From now on, Nvidia Geforce RTX 3080/3090 and AMD Radeon RX 6800/6800XT/6900XT/6950XT graphics cards (based on the respective reference design) can be actively water-cooled in the smallest space.
In order to save space in width and height during installation, the input and output have been relocated to the rear of the cooling block. The positioning of the connections makes the hosing much easier and thus enables the easy integration of the GPU cooler into the water circuit even in the tightest server housings. Thanks to the compact design, only 1 slot is required for mounting the cooler in the server rack instead of 1.5 slots as before. Alphacool enters new territory here with the choice of materials. The cooler top is made of carbon with the result that the water cooler is significantly lighter compared to Alphacool's ice blocks with acetal or acrylic tops.
The ES GPX Copper/Carbon GPU cooler also impresses with performance! Alphacool manages to position the cooler in the best possible way close to the components to be cooled. The maximum possible reduction of the thickness of the copper block and the optimization of the water flow inside the cooler allow that all important components such as GPU, voltage converters and VRAMs are cooled by the water much better and more effectively.​
Technical data cooler
Material coolernickle-plated copper
Material cooler topcarbon
Threads2 x G1/4"
Thickness cooling fins0,6mm
Pressure tested0,8 Bar
Technical data backplate
Materialaluminium
(1) Alphacool ES GPX-A Radeon RX 6800/XT/6900 Reference Copper/Carbon with Backplate
- AMD Radeon RX 6800 Reference Design
- AMD Radeon RX 6800 XT Reference Design
- AMD Radeon RX 6900 XT Reference Design
- AMD Radeon RX 6950 XT Reference Design
(2) Alphacool ES RTX 3080/3090 Reference Copper/Carbon with Backplate
- Nvidia Geforce RTX 3080 Reference Design
- Nvidia Geforce RTX 3090 Reference Design
shop offer >>> Alphacool ES GPX AMD & Nvidia Reference Copper/Carbon GPU Cooler
cmcfirm
Can I trade you my existing 4 warped Alphacool blocks for the new carbon version for my Reference 3090s? Would love to get this system up and running and I need the side exits for the ports on a reference block that only you are making. I have this on a Ryzen 9 5950x with 128GB of RAM.
Thomas_S
Sure. If the reference acrylic cooler fits, then the carbon variant is also compatible.
cmcfirm
Thanks Thomas! How do I send these back to you to get the newer non warped replacements?
I will shoot the install with Black Magic 6k Cinema Cameras and post on YouTube.
Merry Christmas!
