Alphacool presents the ES 1 1U. This cooler was specially designed for the requirements of server cooling and is based on the proven technology of the Core 1.
Alphacool combines the best of two worlds with the ES 1 1U. The innovative 3D jetplate in combination with the proven cross-slot technology ensures that the coolant is distributed evenly across the cooler base. Inside the cooler, an O-ring ensures a precise flow of water and thus guarantees reliable cooling.
The cooler has a particularly compact design. With side connections and a flat profile, the ES 1 1U can be easily installed in small systems with limited space, including 1U server casings. The new mounting system and use of acetal for the housing reduce both assembly effort and costs for large-scale production.
The ES 1 1U is now available in the Alphacool online store.
Features:
Features:
- Dimensions (L x W x H): 70.00 x 70.00 x 26.00mm
- Housing material: acetal
- Cooler material: nickel-plated copper
- Threads: 2 x G1/4”
- Fin thickness/spacing: 0.4/0.4mm
- Maximum operating temperature: 60 °C
- Intel: LGA 1700
- AMD: AM4, AM5
