Alphacool today presents two new Core temperature sensors with colour display. With the help of the digital display, the temperature of the water cooling loop can be displayed and easily read with an accuracy of 0.1°C. Thanks to the colour scale, you can always keep track of critical temperature ranges.
Alphacool's Core temperature sensor is available in two different versions. One version features a flat and flexible sensor that is simply attached to the outside of the component to measure the temp. Variant 2 has a sensor with 2 G1/4" female threads that can be integrated into any water cooling loop using suitable adapters. It does not matter whether the system is equipped with hoses or hard tubes.
The Core temperature sensors are powered by a 12V 4-pin Molex connector and have sufficient cable length for convenient routing within the water circuit. Additional software for reading the temperature ranges is not required.
1. Alphacool Core Temperature Sensor with C/F Display ( >>> offer)
Technical data | |
Dimensions display | 47,8 x 28,2 x 16,7 mm |
Typ Display | multi-coloured, indication optionally in °C or Fahrenheit |
Sensor type | NTC 10 kOhm thermistor |
Power connection | 4-Pol-Molex (12 V) |
Power cable length | 550 mm |
Length sensor cable | 1000 mm |
Temperature measuring range | -50 to +110 Grad Celsius |
2. Alphacool Core temperature sensor G1/4 IT/IT - with C/F display - Deep Black ( >>> offer)
Technical data | |
Connection (sensor) | G1/4" internal thread |
Length sensor cable | 970 mm |
