With the ES "HighFlow" flow and temperature sensor, the Rise 6W/mk thermal compound and the AlphaTube HF 19/13 Ultra Clear hose, Alphacool today presents three new products in the Alphacool range that no water cooling loop should be without.
One sensor, two functions! The Alphacool ES "HighFlow" is a combination of flow and temperature sensor, which can be integrated at any position in the water circuit due to its very compact design. Due to the use of acetal, the sensor is extremely light at only 45g.
Alphacool's Rise 6W/mK thermal paste is clearly one of the favourites when performance and easy application is required. The thermal paste is electrically non-conductive and very well suited for high contact pressures. Thanks to its consistency, even the smallest height differences between the components to be cooled are compensated for and the heat generated can be dissipated better.
There is a large selection of different versions of AlphaTube HF tubing. This makes it easy to find the tube that best suits your taste. With the AlphaTube HF 19/13 in Ultra Clear, another variant is now available.
Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
Alphacool Rise Thermal grease 6W/mK 4g
Alphacool AlphaTube HF 19/13 Ultra Clear 3m
For further information you can visit our shop: Alphacool ES flow and temperature indicator "HighFlow", Rise Thermal grease 6W/mK & AlphaTube HF 19/13 Ultra Clear
Technical data | |
L x W x H | 58 x 25 x 25 mm |
Material | Acetal |
Threads | 2x G1/4" inner thread (for max. 5mm thread length) |
Cable length hall sensor | 420 mm |
Cable length temperature sensor | 435 mm |
Technical data | |
Contents | 4g |
Thermal Conductivity | 6W/mK |
Technical data | |
Length | 3 m |
Tube size | Ø-outside 19 mm / Ø-inside 13 mm |
Material | PVC |
Hardness grade | 65-70 A-Shore |
Working temperature | -10 - 80°C |
Working pressure | 2 bar |
