Alphacool today presents the HPE-45 and HPE-60 X-Flow, the new generation of high-performance radiators from Alphacool's proven NexXxoS full copper radiator series.
What is new? With the HPE series, Alphacool increases the number of cooling channels within the radiator. This change gives a significant increase in cooling performance without increasing the restriction in the radiator. Another performance-enhancing feature of Alphacool's HPE series is the high fin density. With a fin spacing of 15 or 16 FPI, it enables an optimal flow of air. If the radiator is equipped with 80 mm fans on both sides in push/pull mode, a significant reduction in water temperature is demonstrably possible compared to standard radiators.
The NexXxoS HPE-60 all-copper radiators also feature Alphacool's proven X-Flow technology. This means that the Inlets and outlets are located on the opposite sides and thus enable an easy realisation of a water circuit within a server rack. The 60 mm thick radiators can be equipped with three or four 80 mm fans per radiator side.
1. Alphacool NexXxoS HPE-45 Full Copper 80mm Triple Radiator
L x W x H | 286 x 80 x 42 mm |
Material cooling fins, channels & prechamber | copper |
Material outer housing | steel |
Fins per Inch | 16 |
Threads | 2x G1/4“ |
Fan size | 80 mm |
Fan slots | 3 one-sided / 6 double-sided |
(>>>Shop offer)
2. Alphacool NexXxoS HPE-60 Full Copper X-Flow 80mm Triple Radiator
L x W x H | 287 x 80 x 60 mm |
Material cooling fins, channels & prechamber | Kupfer |
Material outer housing | Stahl |
Fins per Inch | 15 |
Threads | 6x G1/4“ |
Fan size | 80 mm |
(>>>Shop offer)
3. Alphacool NexXxoS HPE-60 Full Copper X-Flow 80mm Quad Radiator
L x W x H | 367 x 80 x 60 mm |
Fan size | 80 mm |
Fan slots | 4 one-sided / 8 double-sided |
(>>>Shop offer)
