Cable clutter was yesterday! With the new Core Splitters in 3 variants, Alphacool facilitates cable management for PWM controlled fans and aRGB LEDs in your computer. Their compact design allows the splitters to be installed even in the tightest spaces, thus optimally structuring the cables in the computer case.
The Alphacool Core 10x 4-Pin PWM Splitter allows up to ten fans to be controlled simultaneously by the mainboard via PWM and to regulate their speed. Six aRGB illuminated fans can be connected to the Core PWM/DRGB Splitter to control the speed of the fans and their aRGB settings. Alphacool's Core DRGB Splitter has eleven connectors for controlling digitally addressable RGB LEDs on CPU, GPU coolers, fans, AiOs or reservior tanks.
The splitters can be installed anywhere in the computer case using the included Velcro tape to save space. They are powered by a SATA connector of the PC power supply.
Technical data:
- Dimensions: 79,75 x 46,47 x 12,6mm
- Threads: 10x 4-Pin PWM (Fans) | 1x 4-Pin PWM (Mainboard) | 1x SATA (5V)
- Maximum power consumption: 54W (4,5A)
Core 6x 4-Pin PWM/DRGB Splitter
- Dimensions: 95,92 x 49,91 x 14mm
- Threads: 6x 4-Pin PWM | 6x 3-Pin aRGB (5V) | 1x SATA (5V) | 1x 2-Pin (Splitter IN)
- Maximum power consumption: 22,5W (4,5A)
Core 11x 3-Pin DRGB Splitter
- Dimensions: 91,9 x 46,43 x 12,5mm
- Threads: 11x 3-Pin aRGB (5V) | 1x SATA (5V) | 1x 2-Pin (Splitter IN)
