NexXxos Nova1080
Hakanese
Hi was looking at getting this radiator, and the fan box, and I was wondering if there are mounting pounts on the side of the fan case box to mount a reservoir pump combo?
Thomas_S
Hi. There are some prepared screw holes on both sides for additional mounting of extra accessories. The mounting of a reservoir pump combo should be possible.
Hakanese
Looks like I get to retire my 480 Monsta rads. Thank you for the fast reply, and am I correct to believe that the pressure drop on the Nova is very low too?
Thomas_S
What do you mean by pressure drop? It's a closed system, so there should be no pressure drop after start-up. Or do you mean the possible restrictivity of the radiator?
Thomas_S
This is very low & with a strong pump there should be no problems. So far there have been no complaints with the radiator ;-)
