Alphacool expands the portfolio of the Enterprise Solutions series for graphics card water coolers and presents today the new ES RTX A5000 GPU cooler. The PNY Nvidia RTX A5000 GPU can now be actively water-cooledwith Alphacool's ES RTX Fullcover copper cooler.
The water cooler is made of copper and acetal and comes with an aluminium backplate. It is specially designed for use in tight server cases. In order to save space in width and height, the connections have been moved to the rear of the block, which also enables easier tubing within the server rack. Despite its compact design, this acetal water cooler has the same performance features as the coolers in the Eisblock Aurora acrylic series. Smart and efficient.
- PNY RTX A5000, 24GB GDDR6, 4x DP (VCNRTXA5000-PB)
Technical data cooler | |
L x W x H | 254,48 x 97,19 x 26,6mm |
Material cooler | Nickle-plated copper |
Material cooler top | acetal |
Threads | 2 x G1/4" |
Thickness cooling fins | 0,6mm |
Maximum working temperature | 60 °C |
Pressure tested | 0,8 Bar |
Technical data backplate | |
L x W x H | 216,55 x 95,43 x 6mm |
Material | aluminium |
Color | black |
