Parts for Alphacool Eisbaer 280 AIO CPU Cooler - Black (11287)
vincinator44
My pump stopped working and the plastic housing melted before the system errored. I want to re-use the radiator/fans with a custom loop (core1 + reservoir/pump). I've identified all parts (tubing, anti-coil and fittings) but a flat rubber washer (oring?) between fitting and radiator.
Is there a part breakdown for this AIO assembly?
vincinator44
Besides the oring seal ob the fitting (g1/4 8/11) on the radiator, there is a second gasket (not oring, but flat) between the fitting and the radiator. I can take a photo and post.
Please make a photo, easier to understand exactly what you want. Thanks.
The ‘inner’ O-ring you see there is actually the O-ring from the sealing plug that was probably in there before. It has to come out, you don't need it. It should actually come out when you unscrew the sealing plug, but has obviously got stuck inside.
