Physical approval match for 11684 kit
Elior Zeno
I got an ASUS RTX 2070 Super
TURBO-RTX2070S-8G-EVO
I can confirm physical match between TURBO-RTX2070S-8G-EVO and kit 11684.
Great results btw !
Vanzin
Hi,
at the moment we do not have an water block for the EVO Series in our assortment. So this water block is not compatible with your GPU.
Elior Zeno
Please read again, I wrote I CAN CONFIRM IT IS COMPATIBLE !
I have it installed - it fits and works great.
Thank you
Elior
@Vanzin
He said... the cooler fits on the TURBO-RTX2070S-8G-EVO . So maybe we can put it on our compatibility list too for that cooler.
Vanzin
Oh I am missread it. I am so sorry. Thank you very much for the information that it fits. I will update our lists asap. May I ask if you have a photo of the PCB Layout and if we can use it for our configurator?
Numitor
Hi.
I'm starting an upgrade Asus TURBO-RTX2070-8G to Asus TURBO-RTX2070S-8G-EVO
My gpu waterblock is 11683
I assume TURBO-RTX2070S-8G-EVO is compatible to 11683 ?
Metropolis34
What is the PCB number of your card? You can find it on the original packaging or on the fornt/back side of the card.
Vanzin
your New GPU is using a different PCB Layout and at the moment we do not have a water block for it in our assortment but we are already producing one for it and it will be available in few weeks.
Numitor
So, thanks for reply. Then I'll suspend the upgrade.
