In a view 37 chassis, currently using only a Eisbaer Aurora 360(side mount) and after seeing it in action I couldn't wait to expand this to my 6800 qick 319 GPU.
I've been pondering on what I need and after some advice from staff at Alphacool, I know I need a pump and was suggested the DDC310 version of the Eisstation. I was also suggested the quick connector type tubings, adding to that more liquid for filling, 240mm rad with fans and the GPX MERC 319 GPU block and I'm now at a conundrum.
I'm assuming i'm going to need 3? sets of the tubes(unless i get a rad fitted with tubes) and the sequence would be something like this;
CPUOUT>GPUIN(set1)>GPUOUT(set1)>EISIN(set2)>EISOUT(set2)>240IN(set3)>240OUT(set3)>360IN>360OUT>CPUIN
Are there any special fittings I will require at all? or is it just, three sets of the tubes nothing else needed?
The logistics of all the hoses is going to be a bit of a problem as well, they are pretty long while the distance some have to go is extremely short, like between the new pump and the first rad while from the first to the 2nd radiator I'm not even sure if the hoses have the length required. They all have to avoid the fans spinning from the side of the case on the aurora radiator as well. (case has one front mounted rad and one side mounted.) Option is a 120mm rad in the back instead of the front mounted 240, which would then be between the CPU and GPU and might actually be the most logistically sound option. But I'll think more about that and bring out the tape measurer once I know if I need fittings or anything special at all.
Thanks!
Thanks!
