Project Black ice
Shypax
So this is my baby, my daily driver;
https://imgur.com/p0PoqVI
Specs ;
Intel i9 9900k @ 5.1ghz
Asus Maximus hero XI
Asus 1080ti strix
32gb Gskill tridentZ rgb @ 3000mhz
Corsair RM750x white special edition
hardware used:
Lian li pc o11-dynamic white
2 x xspc 360 rads
6 x EK vardar
Bykski CPU block
Bykski Gpu block
Fittings by barrow
pump/res raijintek Antila D5
Mayhems pastel white fluid
Alphacool rgb strips
Cable mod pro carbon cables
RGB hubs by xspc
Deepcool fan hub
BethCross
great job, not sure I like the milk coolant after seeing how bad time jay has had with pastels over the years also so much tube! but looks wise! top notch, real nice looking forsure!
Shypax
yeah the white fluid is basically a test to see if it has improved, i got several jugs of water ready to clean it out :)
i wanted alot of tubes with the colored fluids, also i like busy cases ,and in this case its hard to fill out properly
also the corner above rear IO is tricky as hell to reach with fittings cause its a smaller "front room" than a normal pc would so rads cant move that much which is the only downside tbh
War4peace
After almost two years of Pastel White (without changing liquid at all) AND soft tubing on top of that, there is nothing else I would use at the moment. I also got Pastel Red and Pastel Black in my storage, ready for other builds :)
