Just starting to built my water cooling loop (first water cooling system since many many years) and started wondering if it´s better to add pump before or after GPU?
Thinking what is the temperature of the coolant once it leaves the GPU block? Would it be better if the coolant goes directly to radiator and then cooled liquid goes to pump? Or does it matter at all?
I have Eisstation (#13297) pump, Eisblock GPX (#11681) GPU block and NexXxoS ST30 (#14344) radiator. GPU is RTX 2080Ti FE.
Thank you for any hints.
