Pump not running/liquid not moving high temps
Krisb137
Hi, recent purchased a
Alphacool Eisbaer Pro HPE Aurora 360 CPU AIO​
for my 14900k to replace a different AIO as I also have the nexxos radiator expansion kit and I thought 2 radiators would help me run the fans quiter.
Unfortunately it seems that the pump isn't running or the liquid isn't moving.
This is from idle just from starting up and typing this out.
If i look at the pump block though I can see an air bubble at the top that isn't moving at all, if I load any game such as warcraft for instance cpu immedietly goes to 100c and stays there.
I have tried reseating the cpu block incase it was a bad mount but it wasn't and it didn't change anything.
I have also tried having the pump cable plugged into the motherboard aio pump slot as well as trying it with the adapter with the controller that it came with but I get the exact same.
In my bios I have all cpufans/chassis fans set to PWM 100% at all times as well.
The lights come on for the pump and the controller will change the colours/mode etc but temperature as soon as I do anything is a major concern.
Feeling the cable/tubes it doesn't feel as though any water is moving around
Krisb137
I'm not sure what changed but it is now working and I can feel the liquid moving in the pump.
However The temperatures whilst better than the above still aren't great
Idle/as im typing this 1746803570229.png
If i load up warcraft
