Current setup: Asrock TRX40 Creator + AMD 3970x + 2x Inno3D 3090 iChill X3 with stock air-cooler.
I use the machine for ML, not for gaming.
I want to upgrade with additional 2x 3090 GPU's, but due to the size of the stock cooler, and the spacial constraints of the motherboard, there is not enough space for 4 air-cooled GPUs, so i'm looking at watercooling.
The Alphacool Eisblock 3090/3080 for reference design 3090 seems like a good waterblock option.
But is it possible to connect 4 of them? Should i use this Alphacool Eisblock Aurora Terminal ?
There is only a 1 slot gap between each PCIe 4.0 on the motherboard, so the cards will be quite close to one another.
Note, i have no experience building custom loop water-cooling, the CPU is currently watercooled, but AIO.
