Question to Eiswolf 240 GPX Pro for 2080ti
AgreSith
Hi!
I have a ASUS Dual GeForce RTX 2080 Ti OC and would like to put an AiO with a 360mm Radiator on it :)
I would get the Eiswolf 240 GPX Pro (Nr. 11684) and buy a separate Radiator (Nr. 14264) for it.
Now i have three questions though:
- Which fans would I need to get in addition to the Radiator? It doesn't seem like the fans on the Eiswolf are being sold separately...
- Can i then return the 240mm Radiator after switching them?
- Do I need anything else for this to work?
Many thanks in advance!
Greetings
Alex
Edit: Answers in german are okay too!
Metropolis34
Hi Alex, first of all have you compared the PCB number of your graphics card at out configurator? I would recommend the Pure Wings fan of Be Quiet.
Sure you can return the 240 mm one back to us regarding credit note. No you dont need anything else to do.
AgreSith
Thanks for the recommendation!
I found this Eiswolf through the Configurator actually, so that should be fine.
Thanks for the help!
Greetings
Alex
