I recently purchased my first Eiisturm 360 kit, as my first watercooling setup, and my new case, after spending some time unpacking it, i noticed that the radiator had a fin or 2 bent or cracked (not the pipes) the overall pack looked opened, but each product seemed new with a few bags seeming to be lil scrunched up like someone had repacked it.
after unpacking more and looking at my case i realised two things.
one the radiator would not connect to the top (cause the plugs protrude and interfere with the mounting in the chassi (lian-li rog dynamic der bauer)
and the water tank fittings (the ones hanging so you can mounting it hanging off the back) are extremely loose)
i looked at a vid and ordered the plugs for the tighter fit along with 200 euros of extras. now when i finally get hte pack i realise these fittings were for a newever version of the reservoir. so they wont acutally help at all.
should i return this whole kit and just get my own? are newer parts i buy going to acutally work with the older parts? im trying to set this up with a 5950x and do my first home built watercooling kit but just getting started is a very long time to set up.
i also want to extend the kit to a graphcis card (3080 or equiv in the next year) have i picked the right stuff? or should i start elsewhere?
