nimbus6446
Hi. I do have a rumbling noise in my new CPU cooler. For what I have discovered this should be some trapped air inside.
If I shake the radiator it sounds not full or at least some air is inside. What would be your advice to do in this situation.
Here is a recording of the sound that it makes.
See the attached video for more info regarding the situation.
Thank you for the support.
