Cre8 Modding
Active member
Hey all, hope you are doing well!
It's time for another build to wrap up 2022 and so I am putting together a build in one of my favorite cases, the be quiet! Silent Base 802.
A huge thank you to be quiet! for sending over this case and a few other bits to get this one going. To start I have the Silent Base and a Dark Power Pro 1200W to throw into this system.
For this build I want to incorporate a display, in the same way I did for be quiets! 20th Anniversary build recently while I was at KitGuru and keep the theme again black and orange throughout, but a little darker than the Pure Base 500FX looked.
Moving on, the motherboard I will be using is the MSI Z690 Carbon Wifi, crammed with a 12900K and full of Seagate FireCuda 510s and 530s, for a total of 8TB of fast NVME storage, and as you can see I will be going with Alphacool as usual for my cooling on this build.
Again a huge thank you to Alphacool for sending over everything I am going to need for this build including an Apex VPP pump, a ST30, and an XT45 radiator, both at 360mm, a 30 Series GPU block, and all-black Eiszapfen fittings. There will be a mixture of hard and soft tubing here as the pump will be located in the spacious PSU shroud and have bulkhead pass-throughs to the GPU and radiators.
So il get some work done and be back with an update soon!
